Design SuiteGrid line instance visibility in viewports
You can select grid lines on a design layer, and easily turn their visibility on and off in viewports.
To control the visibility of grid line instances in viewports:
Select the desired grid lines on the design layer.
From the Object Info palette, click Grid Line Instances.
The Grid Line Instances dialog box opens. All viewports in the file are listed; the viewports for which the selected grid line cannot be displayed, are grayed.
Click in the first column to place a check mark and turn on the grid line instance visibility in the viewport, or click to remove the check mark and turn off the grid line’s visibility in the viewport.
Structural grids
Structural grid visibility in viewports
